OOT Hack: Sequel to MM/Prequel to TP Updated 3/15/14 (Unnamed)
NoSkinnedKoopa
btw, I assembled Jason's code for the 1/2 day repeat in case anyone needs it.
; gameshark code8116DA98 08028116DA9A 88678116DA9C 2400810A219C 2442810A219E FFFE810A21A0 1040810A21A2 0006810A21A4 2400810A21A8 2442810A21AA 0002810A21AC 244F810A21AE 0001810A21B0 AC6F810A21B2 0018810A21B4 0805810A21B6 B6A8810A21B8 2400810A21BC 2442810A21BE 0002810A21C0 244F810A21C2 FFFF810A21C4 AC6F810A21C6 0018810A21C8 0805810A21CA B6A8810A21CC 2400; nemu cheat.ini file[ZELDA MAJORA'S MASK.Cheats]NumCheats=1CheatName0=1/2 day repeatCheatName0Count=26CheatName0Code0=8116DA98 0802CheatName0Code1=8116DA9A 8867CheatName0Code2=8116DA9C 2400CheatName0Code3=810A219C 2442CheatName0Code4=810A219E FFFECheatName0Code5=810A21A0 1040CheatName0Code6=810A21A2 0006CheatName0Code7=810A21A4 2400CheatName0Code8=810A21A8 2442CheatName0Code9=810A21AA 0002CheatName0Code10=810A21AC 244FCheatName0Code11=810A21AE 0001CheatName0Code12=810A21B0 AC6FCheatName0Code13=810A21B2 0018CheatName0Code14=810A21B4 0805CheatName0Code15=810A21B6 B6A8CheatName0Code16=810A21B8 2400CheatName0Code17=810A21BC 2442CheatName0Code18=810A21BE 0002CheatName0Code19=810A21C0 244FCheatName0Code20=810A21C2 FFFFCheatName0Code21=810A21C4 AC6FCheatName0Code22=810A21C6 0018CheatName0Code23=810A21C8 0805CheatName0Code24=810A21CA B6A8CheatName0Code25=810A21CC 2400
I'll convert this to a rom patch once I port it to the normal MM (U) rom
Awesome dude, I love that contribution. Do you want to be apart of this project? Cuz I already know I can't do this by myself lol
My time looping hack doesn't break actors' schedules. I don't know what it does to things that count the number of days, if any. I avoided running the normal "reset to day 1" routine for a reason, though.
While it is probably technically possible to run the game without any of its scheduled entities (see: day 4), it's unlikely that a hack working with that would be particularly interesting. Take advantage of the game engine's features, y'know? I would've done a "loop days 1-3" hack but it wasn't feasible for me to figure out how to prevent the end of the world sequence at that time.
Edited by wareya
M​y debug rom of Majora's Mask has the same file and data as the normal rom of Majora's Mask, and I don't want the debug rom to interfere with my normal rom.
EDIT: Never mind, the debug rom was baloney.
Just in case you didn't know, controller #4 has to be plugged in to see or use the debugging features, otherwise the game looks entirely normal. you could have already had it
sorry dude, spoken for, I'm on the PZGD..err..well now Project Antiqua team...but I don't mind helping if you need it.
It's all good, and I'll really need your help, thanks dude.
WOW! *Facepalm* I would had never guessed.
Is there anything left from the rumored "MM was supposed to be seven days originally"? I've only seen that in passing on forums and such, never really confirmed if that was true. Perhaps there's some sort of leftover coding from it?
Uh, I don't have a slight clue about that, but the day cycle will be a repeat of days 1-3 throughout the game with of course, edited NPC stuff so when the cycle starts over, nothing looks weird.
how exactly would removing the time limit change the game play?would you be adding the scrapped feature of being able to "Buy" more time?
also could you explain in more detail of the significance of the ocarina of space?
because if it was just a magical tune he played, a model of the fairies ocarina from OOT would suffice.
I will not add the feature of "buying time." The game will just repeat the days over and over, and I will edit the text of the people relating to the time limit. Also, I personally think I revealed a little bit too much on the story intro ;). If you want more information on the story, join the project and help me create it.
im actually helping with tainted blade at the moment, and im really new to moding Nintendo 64 games at this time.maybe later?
It's ok! You could work on 2 projects or help later or whatever.
I have virtually no knowledge of modding MM...but I always HATED the time limit. If you are able to create the adventure (or make your own) where that time limit doesn't exist...by God, I would play this!
Haha, you don't need modding knowledge to contribute! I only know how to Text Edit so far! You could model, draw/create concept art, compose music, or help me with the story!
  • 5 months later...
How much music would you need?
A lot. I'm planning for some themes to be remixed, and other new original music as well.
Amaaaazing idea, PLEASE don't give up!
what about add some areas of Terminas as well, maybe you could make a path between hyrule and termina in lost wood, that would be amaaazing!
Well, the Lost Woods has been expanded to detail the border between Hyrule and Termina. (Since Link's and Skull Kid's treehouse is in the Lost Woods, between Hyrule and Termina.) Also, I am planning to have another explore-able region/kingdom, which is where the enemy is coming from.
  • 4 months later...
Okay, after many months of laziness, I finally decided to do something and start this baby up. Don't expect many updates as I literally have a laziness problem. Now then, I decided to start small and edit Hyrule Field to create an entrance to one of the new locations I have planned: The Battlefield Wargrounds. This area is of course a Battlefield, where the Hylian soldiers battled(or are battling) the army of the antagonist. The entrance to that area can be found on the upper left part of Hyrule Field, as shown here:
Before:
After:
This was quick, and obviously not final. The point of it was to give a you guys an idea of what's coming up. ;) Next, I'll go for Kokiri Forest or a new location.
Before:
After:
You should add a small bridge over the water. It would make it look more convincing.
I LITERALLY THOUGHT THAT. I didn't do it now because I wanted this to be quick. But yes, I will add a wide bridge so the soldiers don't need to go through water every time they go and come back from battle.
