Megaman X3
Gamemaster: Shadow Fire
REMAINING TIME
TIME HAS EXPIRED!
You are all hereby challenged to play Megaman X3.
Megaman X3 is the third game in the Megaman X series, created by Capcom and released on the Super Nintendo.
CONTENTS
The download pack will contain the following:
    [*]Megaman X3 [*]A copy of the rules and some info [*]A text file, titled after the game, for completion time/date to be recorded, along with any comments you wish to provide.
If you need an emulator, click here.
RULES
There will be a few rules in place to allow for a fair go:
    [*]You must complete the game from start to finish. Once you are complete, you must record the time it took you to beat the game. [*]The clock must be initiated upon pressing START, stopping only once the credits are complete. [*]No save states are to be used. [*]You are not permitted to use passwords. Passwords are given upon loss of all chances, however, even upon earning a GAME OVER, time must keep ticking. You will still be able to select CONTINUE to retry from where you last were. [*]No game guides are permitted to be used, aside from the original instruction manuals which can be found online. [*]Sound must be enabled, and playing clearly for you. For the best experience, the music and sounds are necessary. [*]External controllers are permitted, to make things easier (or harder, depending on your setup). If you own the game cartridge and console, you may use that, or if you wish to play on an alternate emulator, that is also permitted. [*]Do not post your times here. Instead, send me a PM with the provided text files, subject name being Megaman X3Challenge.
The community challenge will have a deadline: 10:00PM on November 20, 2012 (Australian Eastern Standard Time). You can use an online timezone converter to find out when exactly that is in your timezone, or simply look at the provided countdown timer above.
PRIZE
The person with the fastest overall time will be awarded with a prize.
CONTENDERS
    No contenders at this time...
DOWNLOAD
To download the pack and get started, click here.
Download, and enjoy! Good luck!
Guest
This topic is now closed to further replies.
